  • March 20, 2019, 03:17:55 PM
Author Topic: Looking for a magneto that will work on a 2004 carb bike  (Read 247 times)
dhabicht1
« on: June 29, 2018, 02:53:55 PM »
Anybody have one they may want to sell before I start looking for other sources?
Re: Looking for a magneto that will work on a 2004 carb bike
« Reply #1 on: June 30, 2018, 01:10:23 AM »
All carby era magnetos will work.
Where are you?
UK? Ask Cloud.
USA? Ask albertinhouston.
« Reply #2 on: July 04, 2018, 10:39:02 PM »
I have a spare one for a GT125. It's a thinner unit and takes less power to run, which means you'll get more speeeeeed.
dhabicht1
« Reply #3 on: July 10, 2018, 07:02:51 PM »
Long story short I bought an 04 naked carby with a seized engine.  Bought a 2014 EFI 250R engine and put that in the carby bike after switching the carbs over  I then switched the EFI magneto out with the one from the carby engine including the stator and this thing still won't start.
« Reply #4 on: July 10, 2018, 09:28:09 PM »
Check the wiring for the pick-up coil.
Coming out of the motor on the magneto side there are 5 wires. Three are the yellow stator wires and the other two are for the pick-up coil. One is blue and the other green. Make sure that they are connected to the right connector. The connector for the pick-up coil is the exact same type as the connector that charges your loom. Check that the blue/green connector is connected to blue/green on the wiring loom side and not switched around with the Brown/Black connector that is for charging the loom.
