  • February 24, 2019, 02:23:47 AM
Author Topic: 2015 efi Magneto puller size  (Read 198 times)
dhabicht1
« on: July 01, 2018, 07:48:01 PM »
Anyone no for sure what size the puller is for this model measuring it looks like 30mm but can't get the micrometer in to measure the pitch.  I can assure everyone it is not the same size as the 2004 carb model. ask me how I know
Re: 2015 efi Magneto puller size
« Reply #1 on: July 01, 2018, 09:05:03 PM »
I don't know about the 250's, but at least with the 650's, the magneto on the EFI model is not compatible with the carby bikes and vise-versa. The EFI magnetos have 13 crank sensor triggers and the carby models only have 7. The CDI senses things all out of whack.
As for removing the magneto, just use a bolt. find the right size of bolt, i.e. on the 650s it's M20x1.25 and tighten it into the threaded hole. The hole in the crank is much smaller, so the bolt stops on the crank, as you tighten further, the magneto just pops off, nice and easy.
dhabicht1
« Reply #2 on: July 02, 2018, 12:57:02 PM »
Thanks for the reply but it is not the screw in bolt type.  It has a large threaded section which is part of the magneto that the tool screws onto then the center of the tool has a bolt that you turn against the shaft to pop it off.
« Last Edit: July 02, 2018, 12:58:41 PM by dhabicht1 »
dhabicht1
« Reply #3 on: July 10, 2018, 07:05:55 PM »
Just in case anyone wanted to know the size it is a 30mm X 1.5 RH
