  • February 24, 2019, 02:26:08 AM
Author Topic: Help me out, my little Hyo scares me  (Read 513 times)
BalintHU
  • App developer
« on: July 03, 2018, 08:21:38 PM »
Hello guys!
I have a 04 GT250 with 50k km at the clock. Overall the bike is in a really good shape.
But about a week ago she's sharted to make a little "clicking" noise, but only at 4500-5500rpm almost at the "flat spot". The interesting fact in this !!really low volume noise!!(Only hear it with ipon visor and city speed) , it's coming when the bikes get enough warm, after a ~ twenty minutes of riding.
Any idea what could it be ?
Some info:
Used Motul 5100 10W40 from 32,000km to 50,000
Now use Motul 7100 10W40 from 50,000 -> now(50,300)
She did it with the 5100, but get more quit with the 7100.(almost unhearable but it's there)
She got a new front tensioner at 47k km.  (Only asked the mech to take a look at it... he changed it... but he said the old one is in good condition too)
The bike in the hot weather about a week earlier before the little noise started, has run a bit rough at high rpm (8-9,000) and was like one of the cylinders made one or two missfires. (Then left the Shell Premium 95 fuel and this thing gone)
She hasn't got any strange noise on deaceleration.
The bike has totally good and pretty well sound at idle. But if u  rotate the trottle -> and u reach 4500 this noise come but way quiter than "on load".
Re: Help me out, my little Hyo scares me
« Reply #1 on: July 07, 2018, 07:09:30 PM »
What exactly scares you  ::)
BalintHU
  • App developer
« Reply #2 on: July 08, 2018, 05:51:24 PM »
What do u think?!
This ticking noise, at the range of 4,500-5500rpm.
What is only hearable after the bike warmed up totally (15-20 min ride)
« Reply #3 on: July 08, 2018, 11:07:38 PM »
Hi voltage spark jumping around where it shouldn't
BalintHU
  • App developer
« Reply #4 on: July 09, 2018, 12:33:56 AM »
Hmm hiw can i chack that?
If i think about it, this problem started after a spark change, she got two new CR8E NGK spark.
« Reply #5 on: July 09, 2018, 07:18:51 AM »
Get it hot,  put it a dark place and see if you can see any blue sparks.
If that don't work, start by changing your HT leads and go from there
It sounds like your leads or Coils are breaking down.
« Last Edit: July 09, 2018, 07:23:14 AM by spit051261 »
BalintHU
  • App developer
« Reply #6 on: July 10, 2018, 02:07:50 PM »
Ok i tried sg, because I get this simpton after a spark plug change. I made a test drive with the OLD sparks. Now, this annoying noise almost gone, u have to lean side while ride and listen too hear that noise.
Soo almost unnoticable except u know what was it like.
Maybe ignition coils are dying and the new sparks were too much for them ?
If i have to make a tip, maybe the bike has a kind of preignition ? Because with the old sparks almost no noise, only noticeable (and hardly... but way way lower volume noise than before*) when the bike is hot, warmed up.
« Reply #7 on: July 10, 2018, 11:47:40 PM »
Did you drop a spark plug before fitting  ?
A slight crack/fracture in the porcelain will allow the spark to "leak" through the body of the plug.
A Copper spark plug should last a long time and an Iridium will last longer than your bike so the old ones are probably fine .
Just fit new leads and coils with the old plugs .
Auto HT faults are not always easy to find and normally the best way forward to is to change any suspect components in the circuit .
"Normal copper plugs only last about 20,000 miles. However, using platinum plugs can give you 60,000 miles of use. Other types can last up to 100,000 miles."
Right then , we have helped you so now it's your turn to put some pictures up of your bike and introduce yourself at the Korider cafe , at the top of the home page  ;)
« Last Edit: July 11, 2018, 12:12:11 AM by spit051261 »
Galacticaone
« Reply #8 on: August 04, 2018, 01:15:30 AM »
Hello
Pull your spark plugs and see if you are running lean.  The tip of the plug will be on the white side if it is running lean.
If you are getting noise from the engine, it is usually from the valves.  If it is running fine other than the noise, I would recomment to run it to the end of the season and then pull the heads and check out your cams, cam clearance and the condition of the valves.
Try to listen to the engine and see which cylinder is making the noise.
Martin
BalintHU
  • App developer
« Reply #9 on: August 08, 2018, 08:37:29 AM »
Wow thanks, the rear plug is white as f*ck. I think ~400-500km had to be enough to turn into deet brown. The front one is a kind of coffe brown, i think  thats ok.
I gotcha the problem... i had a carb sync at the spring. But my rear carb pipe (the one that lead from the carb to the head.) was a bit off. Maybe the mechanic has synced overally wrong the bike cause this?
If my small knocking, coming from the chamber during work cause the mixture is lean, why didnt we noticed it immediately???
