  • February 24, 2019, 02:25:31 AM
Author Topic: Bike won't start Bad Starter??  (Read 237 times)
SB_Rocketboy
  • Ad Astra
« on: July 11, 2018, 02:07:47 AM »
Took my bike for a long ride with unbalanced carbs, rattled the battery bolts loose 75 miles into the ride and towed it home. It's been in storage for the past 6 months. Just bought a new battery to try and get her to start. How crappy are the Hyosung starters?
https://imgur.com/a/XY9xleu
AIS block off
Re: Bike won't start Bad Starter??
« Reply #1 on: July 11, 2018, 03:30:14 AM »
Short the main terminals on the starter relay and see if the motor spins and if it doesn't ,it's probably facked .
Could also be wring or motor brushes but by shorting the relay out , you are putting juice straight to the starter ( if the cables are OK  ::) ).
BTW my GT had 30,000K's and the starter was fine .
« Last Edit: July 11, 2018, 03:36:21 AM by spit051261 »
SB_Rocketboy
  • Ad Astra
« Reply #2 on: July 11, 2018, 06:48:01 PM »
replaced the battery and shot some starter fluid and she powered right up!!! Need to balance the carbs now.
AIS block off
« Reply #3 on: July 11, 2018, 08:57:45 PM »
What bike is it , model , year ?
There was me thinking your starter was effed . That was the subject of your thread after all  ::)
« Last Edit: July 11, 2018, 09:00:12 PM by spit051261 »
SB_Rocketboy
  • Ad Astra
« Reply #4 on: July 18, 2018, 05:24:28 PM »
2010 carby comet, the carbs are so unbalanced! with the AF screw backed all the way out the back cylinder still sucks all the oil from the front cylinder home made manometer. No vacuum leaks, sprayed soapy water all over it.
AIS block off
