  • May 24, 2019, 03:59:30 AM
Author Topic: Bike Does'nt start after cleaning the carb  (Read 503 times)
Zabolo
  • Hyosung GT125
« on: August 27, 2018, 09:53:50 AM »
Hey guys, ive ran into a problem. After cleaning my carb i cant start my Gt 125. But the thing is when I spray some of the carb cleaner into the carb it starts instantly but just for a few second. So my guess would be that maybe the carb doesnt get any fuel or something? What should I do? Any suggestions will help. Help me out guys
Re: Bike Does'nt start after cleaning the carb
« Reply #1 on: August 27, 2018, 10:09:53 AM »
It does sound like the carbs are not getting fuel.
Is the float bowl stuck at the top? ..no wait, it can't be that. Both bowls would have to be stuck.
Logic says the fuel supply line is blocked, or incorrectly connected.
Zabolo
  • Hyosung GT125
« Reply #2 on: August 27, 2018, 12:42:10 PM »
The boat flows cant be stuck, I checked them, renoved and put them back together, everything seemed to work properly. Ill check the fuel supply line. Thank you alot.
Stag
« Reply #3 on: September 19, 2018, 07:23:51 PM »
Have you reattached the airbox? It plays a key part in pulling fuel in to the bike, and making it in to a mist rather than a stream of liquid
« Reply #4 on: September 20, 2018, 01:04:38 PM »
They run without the airbox, the fact its firing with carb cleaner suggests hes not got a vacuum to the pump or as umop-ǝpisdn suggested, the floats are stuck shut.
Suck on the vacuum line with the fuel feed to the carbs disconnected, does it piss fuel out? That rules out a vacuum and pump stuck. Then you need to look at the carb bowls again. Uncrew the drains and see if you get any fuel out while sucking on the vacuum pipe to keep filling the carbs.
« Last Edit: September 20, 2018, 01:07:38 PM by Joss »
  • Online Online
« Reply #5 on: September 26, 2018, 04:27:03 AM »
Bike doesn't start AFTER CLEANING CARB .
mmmmmm that's a difficult one .
I had a similar problem when I disconnected the battery and it wouldn't start .
Still waiting for an answer on that one  ::)
« Last Edit: September 26, 2018, 04:29:39 AM by spit051261 »
