  • February 22, 2019, 07:48:05 PM
Author Topic: EFI idle rpm question  (Read 1125 times)
Re: EFI idle rpm question
« Reply #10 on: September 26, 2018, 03:53:28 AM »
Just got back from the shit hole where it was a "cool" 37 degrees  :o   so here is the info as promised  ;)
bobe7316
« Reply #11 on: October 03, 2018, 08:19:21 AM »
A lot of things have changed between the 2 pictures. The idling is down from 1703 to 1396 which is better but lots of other things have changed as well. Did you change these or did the computer change as the idle went down. This is all very confusing. I am thinking more than ever of buying a Honda with a carburetor. I can do anything with a carburetor but this fuel injection is a complication that I can do without.
Bob
« Reply #12 on: October 05, 2018, 04:40:01 AM »
Hi Bob ,
I didn't change anything .
These were all changed by the ECM .
I would say the changes are being made as the engine temp increases .
You could just have a dodgy ECM and the easiest way to see is to try a known good one .
Does your idle lower after running the bike for 5 minutes or so (when it gets hot) or does it stay the same irrespective of engine temp  ?
Looks like my web hosting site has gone down with all my pictures  >:(
« Last Edit: October 05, 2018, 05:14:13 AM by spit051261 »
bobe7316
« Reply #13 on: October 12, 2018, 11:56:40 AM »
Ok finally back again. My new ebay manual states that the Idle of my 2010 GV250EI should be between 1,400 and 1,600 RPM and mine is spot on 1,400 so I am going to leave it at that. It still sounds a little high but if the book says 1,400 and it is then it can stay that way.
Thank you all for your help with this one.
Old Bob.
« Reply #14 on: October 12, 2018, 02:24:44 PM »
That's what my computer says  ;)
