  • June 18, 2019, 12:00:54 AM
Author Topic: C25  (Read 477 times)
Cardillac
C25
« on: October 15, 2018, 04:49:05 PM »
Hello,
after about 180km my GT250i (2011; 16500km) suddenly stopped at a crossroads. After that it could hardly be started and with a noisy engine and almost without power I saved the last kilometers home. When I parked the bike, I saw through the rear exhaust opening that the inside of the exhaust glowed bright red, the outside is now discolored. The diagnostic mode tells me C25, i.e. malfunction of the ignition coil of the rear cylinder. The problem is only that the resistance values of this ignition coil are within the normal range, i.e. 4.1 Ohm on the primary side and 30kiloOhm on the secondary side. Do you have any hints or experiences on what to do now?
Greeting C.
  • Online Online
Re: C25
« Reply #1 on: October 15, 2018, 05:36:36 PM »
Swap coils and see if the fault follows .
Cardillac
Re: C25
« Reply #2 on: October 19, 2018, 07:18:51 PM »
It was indeed the ignition coil of the rear cylinder. I mounted an ignition coil of a GV250i. Then I had to try very often to start the machine but now it runs like before.
  • Online Online
Re: C25
« Reply #3 on: October 19, 2018, 11:12:47 PM »
Happy days  :)
