  • April 23, 2019, 05:47:24 AM
Pages: 1 2 [3]
Author Topic: gv650i sometimes shuts off when pressing clutch  (Read 2214 times)
Re: gv650i sometimes shuts off when pressing clutch
« Reply #20 on: October 26, 2018, 11:48:36 PM »
Have you taken your spark plugs out and checked the tips ?
Dodgy HT leads can give wierd faults
nosidefcp
« Reply #21 on: October 27, 2018, 12:31:17 PM »
in fact, just checked the leads, and the rear one, just with litle pull came out just half of the lead. the rubber tube was broken. repaired it, removed the spark plug, attached to repaired lead and its giging spark so i assembled it again. also spoted a litle tiny hole in the tube that goes from ISC valce to air filter box. changed that rubber tube. oil is changed. gonna check today for the results...
« Reply #22 on: October 28, 2018, 04:51:56 AM »
I would be replacing the HT lead if it was broken .trying to repair them is asking for trouble .
This thread is turning into a war and peace  ;D
« Last Edit: October 28, 2018, 04:54:10 AM by spit051261 »
nosidefcp
« Reply #23 on: January 07, 2019, 06:35:09 PM »
Theo issue still exists and now its happening more Times. It just happens when reducing gears, when riding in downward dias(front) pointing down. Never happens when climbing and/or switching to upper gears.
Dont know What to do...
Can worn out clutch plates do this?
« Reply #24 on: January 20, 2019, 04:43:16 PM »
Clutch plates won't be the cause.
Most likely is the idle speed control valve / solenoid.
« Reply #25 on: January 20, 2019, 10:36:46 PM »
I agree with Sid.
The idle speed control solenoid is located under the fuel tank on the right hand side of the bike.
Look for a device with a thick rubber tube connecting it to the air box and two thin rubber tubes that go to the throttle bodies. If either of the tubes has split, cracked, or has come loose, then idle will be affected. Else, if the ISC motor has died, then that will obviously cause trouble as well.
nosidefcp
« Reply #26 on: February 10, 2019, 10:34:55 PM »
issue seems to be now solved. problem was bad voltage in TPS. was at 1.09. adjusted it to 1.20 and its now fine...it seems
« Reply #27 on: February 17, 2019, 12:03:54 PM »
How did you adjust it , out of curiosity  ::)
nosidefcp
« Reply #28 on: February 20, 2019, 04:02:21 PM »
followed a guide somewhere in this forum. multimeter on the two wires mentinoned. red on red, black on grren yelow. was reading 1.04 i think or 1.09. loosened the top tps bolt, moved the top to front of the bike direction and the voltage started to increase. when it was around 1.20, i tighten the top bolt. made 500km since and the issue never happened again.
Pages: 1 2 [3]
