  • January 19, 2019, 03:23:09 PM
Author Topic: sometimes shuts off when pressing clutch  (Read 549 times)
Re: sometimes shuts off when pressing clutch
« Reply #10 on: October 25, 2018, 06:24:35 AM »
There is 2 separate conversations going from the same person regarding the same fault on 2
Different parts of the forum .gt650 and gv650.
Any chance of combining them into one  .
« Last Edit: October 25, 2018, 06:27:27 AM by spit051261 »
nosidefcp
« Reply #11 on: October 25, 2018, 11:54:35 AM »
sorry for opening the thread two times, but im kinda desperate. lol. i have some motorcycles, so i have pretty sure its not a serious failure from some serious part, since the engine is runing fine, power is great, no errors on ecu. i will adjust the clutch cable today and buy some wd40 to check for leaks and let you know about the leaks
nosidefcp
« Reply #12 on: October 25, 2018, 04:37:03 PM »
adjusted clutch cable. happened again one more time in a 20km ride.
gonna check later today for vacuum leaks. any more tips guys?
« Reply #13 on: October 25, 2018, 09:32:54 PM »
I answered on the other thread and now realise it's efi.
Eliminate vacuum leaks first, then get back to us. Could be an issue with a sensor or the idle speed control valve / sensor as well.
« Last Edit: October 25, 2018, 09:37:51 PM by Sid »
nosidefcp
« Reply #14 on: October 26, 2018, 01:18:18 AM »
yup, efi. gonna check for vacuum leaks. can you post a pic and the location of the idle speed control valve? where can i order one? thanks
« Reply #15 on: October 26, 2018, 08:28:46 PM »
It's this in the link afaik.
Not sure on location as I don't have my GV650 anymore.
https://www.koreanbikeparts.com/index.php/genuine-idle-speed-control-solenoid-hyosung-gv250-gt650-gv650-efi.html
This comes up as well, you may have to look and see which one you have.
Certainly seems it could be the issue.
Personally I don't feel it's electrical, sounds like fuelling to me.
https://www.koreanbikeparts.com/index.php/hyosung-bikes/genuine-idle-speed-control-sensor-hyosung-gt650-gt650r-efi-models.html?SID=4a69fa96bdfdaa5eabe86ff5c29cd66c
« Last Edit: October 26, 2018, 08:33:16 PM by Sid »
nosidefcp
« Reply #16 on: October 26, 2018, 09:01:30 PM »
i think its fueling too. today i removed the fuel tank, removed air filter and the air filter box had some fuel drops. also, since im in time to change the oil now, i removed the oil cap, and the oil has a litle smell of fuel, i think. so something its not sealing in the injection...or a spark plug gone...
