  • April 23, 2019, 05:05:30 AM
Pages: [1] 2 3
Author Topic: Gv650c Aquila stillnot charging replaced RR, battery healthy, stator good reads.  (Read 1187 times)
savisaar2
So today I had my battery tested and the guy said it's healthy so battery is ruled out.
I replaced the RR and tests are good.
I had to fix the stator connection with new female connectors because it was burnt.
I still have no charge going to the battery and I did notice the stator and RR wires are extremely hot.
Anymore ideas guys? Right now I feel like I have to scrap the bike.
Looks like you'll have to scrap it then  ::)
savisaar2
Are charging issues isolated to tho those three parts?
They are the main components associated with a fault but you could have a wiring/ component fault that is draining your battery but start with the REG , STATOR , BATTERY and if they are definitely ok , look elsewhere
Do you trust the guy that tested your battery?
« Last Edit: October 27, 2018, 09:05:52 AM by spit051261 »
savisaar2
They are the main components associated with a fault but you could have a wiring/ component fault that is draining your battery .
Thanks for your input he told me the cranking amps no idea what it means haha but I would expect it to be correct because he would be inclined to sell me a battery. I had it tested at battery world.
With the bike switched off , unbolt the neg and dab it onto the post and see if it arcs .
Still sounds like one of the other 3 though .
savisaar2
Tomorrow I will retest the RR and stator,
As per the service manual tho it says I need to test using ohms and YouTube says to test in continuity? Which one guys?
savisaar2
Do you mean the negative cable from the battery and if so what is arc?
Yes and you are looking for a spark ( like you get when you ARC weld ) to see if your bike is drawing current with everything off .
The OEM wiring loom is sh!t and prone to failures.
1/ Run a duplicate quality wire from the RR positive output direct to the battery positive terminal. Make sure you put a 30amp fuse in it close to the battery.
2/ Run a duplicate quality wire from the battery negative terminal to a solid bolt on the frame or motor.
Pages: [1] 2 3
