  • April 25, 2019, 02:58:20 AM
Pages: 1 [2] 3
Author Topic: Gv650c Aquila stillnot charging replaced RR, battery healthy, stator good reads.  (Read 1189 times)
Tomorrow I will retest the RR and stator,
As per the service manual tho it says I need to test using ohms and YouTube says to test in continuity? Which one guys?
I would be testing for voltage level on both
savisaar2
Finally fixed it guys I trailed the red wire from the RR to the positive terminal and guess what it's broken lol, connecting it together and it charges yay. I also found and unidentified cable not connecting to anything 😮
savisaar2
Just one more quick query does the FI light is meant to me lit before you crank the bike? So mine shows with the red FI light when I turn on the electrics?
savisaar2
Further regarding my last reply FI light indicates 0138 and 0132 which indicate 02 sensor issues, I would like advice I attempted to follow the service manual and check the continuity for sensor side and Heater side on the single plug and one side of each is open?
So after all that  , your REG wasn't even connected  ::)
Have you thought about taking up a different hobby ?
I don't suppose you've checked to see if your  O2 sensors are fitted ....wouldn't surprise me  ::)
« Last Edit: October 28, 2018, 11:58:18 AM by spit051261 »
savisaar2
Mechanics is way out of my knowledge so that's why I am here trying to learn. But the O2 sensors there are two and I have tested them both just not sure if I was doing it correctly. The FI indicator as states both sensors high voltage ?
Doubt both sensors would go so you probably have another fault such as spark plugs , leaking injectors , air filter , vacuum leak etc.
Your bike is running rich which is not great but a lot better than running lean .
« Last Edit: October 28, 2018, 02:10:07 PM by spit051261 »
savisaar2
Wouldn't they have a code of their own sorry if silly question. Also I realised that the other side wont actually give a reading until temp is met so I tested it whiles it's off haha.
savisaar2
After riding for 2 days I had the FI light come on with the error 0562 which indicates low voltage on battery and after having a check with the multimeter she is 11.4v 😥. One thing that I did realise when I connected that positive wire is that the idle volts jumped to 13.8 however manual says it should jump higher with 5000rpm however mine does not? Supposedly I guess this could mean the bike is undercharging I have tested RR and Stator all with acceptable readings. Quick question regarding RR I bought a cheapy off eBay but still reads fine however original RR had a black cable on its right bolt is that normal because from pictures of RR i don't see any cables attached to the bolts of the RR. I mean I could possibly just need to replace the entire wire from RR to battery since I only have joined to break together. I thought I would bring up the thought here before I go on another long chase. Thanks guys I am learning heaps on this forum 😁
Pages: 1 [2] 3
