  • March 26, 2019, 09:08:28 AM
Author Topic: Stator problem?  (Read 539 times)
aLekz
Stator problem?
« on: November 02, 2018, 01:19:02 PM »
got fi code 0562, battery voltages dropping while bike is running. tried to measure voltage from the stator and got 0 in three of them.
Is it the stator faulty?
The rectifir seems be okay, the diodes are fine.
aLekz
Re: Stator problem?
« Reply #1 on: November 02, 2018, 09:55:48 PM »
measured once again, got 10 volts from the stator at idle, abd when reving to 5k rpm i got 20 volts. is it ok?
2turbos
Re: Stator problem?
« Reply #2 on: November 03, 2018, 01:36:53 PM »
1. Check each of the 3 yellow wires output on the stator. Should be 50-60v.
2. If you have a factory type diode style VRR it may be bad.
3. Could be bad connection between the stator and VRR. Check the wiring and connector for burnt
    wires or melted connector.
4. Do the battery direct wire as seen on this forum.
My experience was a bad regulator.
Re: Stator problem?
« Reply #3 on: November 03, 2018, 09:44:38 PM »
Something to note is that the stator makes AC voltage, not DC. The rectifier turns it into DC.
Make sure that you are measuring AC voltage.
Re: Stator problem?
« Reply #4 on: November 06, 2018, 06:59:29 AM »
How do you know the diodes are fine and how did the test diodes/regulator to see they were in fact , "fine"?
Re: Stator problem?
« Reply #5 on: November 06, 2018, 09:24:25 AM »
Some higher end meters have a diode test function, but it's untrustworthy in this situation, since most often the diodes in a reg/rec fail at operating temperature, not at room temp.
aLekz
Re: Stator problem?
« Reply #6 on: November 10, 2018, 07:40:08 PM »
So the stator was fried a little bit, so I gave to someone to rewind them. Now got other problem, i dont get spark.. the engine turn over and all, tested the spark plugs and no spark.
Is it faulty pickup coil?
Re: Stator problem?
« Reply #7 on: November 12, 2018, 11:26:38 AM »
You should check that the plug for the pick-up coil is plugged into the correct connection.
The pick-up coil and the reg/rec output have exactly the same plugs and are easy to mix up, since they are right next to eachother.
The pickup is one blue and one green wire. Make sure it plugs into the connection with the same colour wires. The reg/rec plug is one brown and one black/white.
Re: Stator problem?
« Reply #8 on: November 12, 2018, 12:01:03 PM »
Welcome to Hyosung world where electrical common sense is non existent  ::)
Side note.....
Other than the electrical gremlins , the Hysoung is a VERY underrated motorcycle .
Ask LX who is going back for more  ;D
« Last Edit: November 12, 2018, 12:16:09 PM by spit051261 »
2turbos
Re: Stator problem?
« Reply #9 on: November 12, 2018, 04:53:59 PM »
Very underrated for sure!
Once I straightened out the electrics no problems since.
