  • June 18, 2019, 12:49:02 AM
Author Topic: How to get airbox back on!!!!!!!!!!!!!  (Read 657 times)
  • Online Online
Re: How to get airbox back on!!!!!!!!!!!!!
« Reply #10 on: November 13, 2018, 02:01:29 AM »
Pretty sure you must of changed your initial post
Sure you should it was carby.
« Reply #11 on: November 13, 2018, 04:04:30 PM »
I thought so too.
In the manual it says to remove engine mounting bolts and jack the engine within the frame, clamping everything up, then easing the engine back in place.
Jamleo8
« Reply #12 on: November 14, 2018, 03:32:00 AM »
Yeah my bad I changed it so people would know but is it the same for the EFI model because I can't get it on.
Jamleo8
« Reply #13 on: November 14, 2018, 03:36:21 AM »
There is no way I put it together wrong because I hardly took anything apart I just can't get the airbox back on for my life.
  • Online Online
« Reply #14 on: November 14, 2018, 04:32:29 AM »
They are easy at least my one was .
I can't understand why you are having problems
Maybe you should post some pictures
You have taken the tank off ?
« Last Edit: November 14, 2018, 04:39:55 AM by spit051261 »
Jamleo8
« Reply #15 on: November 14, 2018, 07:53:17 PM »
I will post pictures when I get home and yes I have the tank off I just can't get the airbox over far enough right to get the right boot on.
Jamleo8
« Reply #16 on: November 17, 2018, 02:32:27 AM »
Ok I just tried jacking it up in the frame and that didn't work either
  • Online Online
« Reply #17 on: November 17, 2018, 02:39:07 AM »
You need to post some pictures.
You shouldn't have to remove the engine to fit it   ;D
Jamleo8
« Reply #18 on: November 19, 2018, 05:09:40 AM »
Yeah I figured it out I think the frame is a tiny bit misaligned causing a clearance issue on the right side I will be taking it into a frame shop
