  • June 02, 2020, 12:45:51 PM
Author Topic: No electrics on karion - any ideas?  (Read 670 times)
tIB
« on: December 24, 2018, 05:11:14 PM »
So I took the rt out the other day and it lost all power when I turned the lights on. I turned them off, jumped it and rode home. Tried again after charging my battery and I got the same again - it started and shut off when I put the lights on. This time however the bike is completely dead - the solenoid doesn't click in when o turn the key and I have nothing at all power wise - no horn, break lights, ignition etc.
Any ideas? The battery is fine and I've opened/cleaned contacts on the harness... I'm thinking check the starter relay next?
Re: No electrics on karion - any ideas?
« Reply #1 on: December 24, 2018, 05:31:32 PM »
Sounds like battery to me or dodgy battery connection
« Last Edit: December 24, 2018, 05:33:42 PM by spit051261 »
« Reply #2 on: December 24, 2018, 09:43:37 PM »
No experience with a Karion :(
Fuses?
..how are you so sure that the battery is fine? It does sound a lot like a battery with a few dead cells.
tIB
« Reply #3 on: December 25, 2018, 08:44:00 AM »
I have a spare battery I can check with so will try, though its relatively new and appears to be putting out what it should. Fuse is good, rectifier/regulator appears to be putting out some odd readings outside the range in the manual... might be that?
« Reply #4 on: December 25, 2018, 11:11:09 AM »
Odd readings ?
Care to elaborate .
Try a 'good' battery to eliminate that first .
tIB
« Reply #5 on: December 25, 2018, 08:47:18 PM »
I'll have a go in the morning...
Readings from the rectifier were outside the range listed in the manual - I forget exactly what they were.
« Reply #6 on: December 25, 2018, 10:45:44 PM »
Seems like you are on top of your bike fault so I'll leave you to it .
Good luck .
tIB
« Reply #7 on: December 26, 2018, 12:55:03 PM »
Cheers - I think we've found the problem: shorted the solenoid and the starter motor ticked over. Sent voltage to the relay in the solenoid and the electromagnet/relay didn't engage... Looks like it's the solenoid then.
It was a good time to have my father in law over - I wouldn't have gotten that far alone! Solenoid on order- I'll update when it's running again...
« Reply #8 on: December 27, 2018, 07:40:40 AM »
Also make sure you have a return (ground) on the coil .
You need both feed and return to energize the coil .
« Reply #9 on: December 27, 2018, 09:25:08 AM »
Just to add to what spit said.
The grounding on Hyo bikes is notoriously poor.
