  • July 14, 2020, 03:23:49 PM
Author Topic: BIG ISSUE HELP WITH HIGH BEAM  (Read 429 times)
shane2k
« on: January 18, 2019, 08:45:28 AM »
some reason since yesterday its decided to blow fuses
when I have engine off the high beam works but soon as you use it at anytime of the engine running it blows not sure if I should still check the connection from the handlebar switch to high beam as it works when engine is off
shane2k
Re: BIG ISSUE HELP WITH HIGH BEAM
« Reply #1 on: January 18, 2019, 09:26:53 AM »
never mind I wiggled the connection and found the connector block causing it sprayed with loads of wd40 and seems fine but will after pull block apart if it does it again
