  • July 16, 2019, 12:06:32 PM
Pages: 1 2 3 [4] 5 6 ... 18
Author Topic: Like Carburetor 101 for the total Idiot?  (Read 79910 times)
Mike on the Rock
    • www.seaies.com
Re: Like Carburetor 101 for the total Idiot?
« Reply #30 on: February 27, 2009, 04:26:06 AM »
hey mike, can you tell me what size i should rejet to if i've got a custom straight through end can and also if Im planning on desnorkling or maybe BMC.
Thanks!
what bike? GT/GV 125/250/650?
Ride safe Mike on the Rock
All my Rides are Naked.
http://seaies.com
bkasper_21
« Reply #31 on: February 27, 2009, 04:32:35 AM »
Sorry Mike for asking yet another question lol but I have a 2004 gt250 with bruce fab exhaust and desnorkeled exhaust suggestions on jets/shims? Thanks  for your help Mike
DV-ation
« Reply #32 on: February 27, 2009, 07:41:10 AM »
hey mike, its a 2005 GT250, with a custom made endcan, planning on desnorkling too. Thanks.
Only a true biker knows why dogs stick their head out of a moving car!
Mike on the Rock
    • www.seaies.com
« Reply #33 on: February 27, 2009, 07:44:35 AM »
Hi bkasper_21
I would use 100/100 main jets and see if that works well for you, I shim the needles as high as I can, this should run a little rich, but that is what you are looking for. I use the stock idle jets on my three 250. <remove the 'O rings' in the emulsion tubes that hold the main jets>.
This runs the best in the a.m. when the air is dense.
« Last Edit: February 27, 2009, 07:46:33 AM by Mike on the Rock »
http://seaies.com
pumbaa
« Reply #34 on: February 27, 2009, 05:22:42 PM »
+1 with Mike, 100 mains work well.
2012 Hyosung Comet GT650
2016 Ford Focus
DV-ation
« Reply #35 on: March 24, 2009, 10:45:41 AM »
what do you think is a better option for jetting for my 05 gt250 with straight through endcan:
- 92.5/95
- 95/95
- 95/97.5
- 97.5/97.5
- 100/100
i was thinkin that either 95/97.5 or 97.5/97.5 would suffice?
Also pilot stock 20 or upsize to 22.5 or larger? Thanks
pumbaa
« Reply #36 on: March 24, 2009, 09:44:27 PM »
If you don't change anything on the bike other than the muffler then I'd say this. All you need to do is raise the main jets up one size. So stock is 92.5 up front and 95 in back. Up it to 95 up front and 97.5 in back.
2016 Ford Focus
olds_cool63
« Reply #37 on: March 24, 2009, 09:55:58 PM »
Just curious: when re-jetting, say to 100/100, what kind of gas mileage is being lost?
Nuff said.
olds_cool63
DON'T BE A SQUIDIOT!  8)
Mike on the Rock
    • www.seaies.com
« Reply #38 on: March 24, 2009, 10:04:51 PM »
I get between 50 to 75 MPG with the 100/100 jets on my GT250, how you ride and where is the main variable, also here in the USA we get all types of junk for fuel. I noticed Little change in MPG on the same runs.
My 2000 & 2004 Naked/duel Disk GT250
100/100 mains,
#20 idle jet,
De-Snorkeled air box,
straight through Exhaust,
50T rear sprocket,
160/60-17 rear tire,
Castrol GTX 10W-40
Cams Balanced
Vacuum on case
I am sure that many other things can work, but this is what I have and it works fo me.
« Last Edit: March 24, 2009, 10:15:43 PM by Mike on the Rock »
http://seaies.com
DV-ation
« Reply #39 on: March 25, 2009, 08:43:56 AM »
mike you have my wish list done and ticked!! tell me something how did you get your cam balanced? do you think that could be a cause for the insane vibration i feel? did you get them balanced because you felt vibration or you happened to find it imbalanced?
