  • January 19, 2019, 11:43:22 AM
Pages: 1 [2] 3 4 5
Author Topic: How to rejet the GT650 with photos  (Read 51586 times)
meestabeck
« Reply #10 on: April 24, 2008, 03:32:39 AM »
I really appreciate this post, I feel more confident about doing the rejet myself now. Kudos!!!!!!
Team S, because it is flirty with something left to the imagination! Kind of like a thong! (2005 GT650S, cosmetic mods/ HID upgrade)
Bretto
« Reply #11 on: April 28, 2008, 10:00:41 PM »
Quote from: "kezza69"
can you explain the drilling the side process for me . i see you used a 1.2mm drill but am not sure what or were you drill.
also if i buy these jets and a drill bit , that will be the same as what larry is offering rite?
Read this link - it shows the drilling process - I lost the photos when I uploaded and didnt want to pull it all apart again to take more.
http://members.optusnet.com.au/sv650-k2/Rejetting_Notes.pdf
Read the information as he has a lot of good stuff that you can use.
2006 GT650R, derestricted, rejet, mod airfilter, Screaming demon exhaust, stainless braided brake lines, Metal Gear brake pads, Carbon fibre look mirrors with inbuilt blinkers and brake light modulator.
kezza69
« Reply #12 on: April 29, 2008, 01:37:10 PM »
thanks bretto.
your right there's plenty of good info there.
cheers
2007 gt650r carbon mirrors,blinkers and Res-art tail eliminator .
14 tooth sprocket
black tint screen.
S/D 304 shorty
Hel brake lines
Larry cook jet kit
what dosent kill you , only makes you stronger
spriceii
« Reply #13 on: May 02, 2008, 02:49:50 AM »
Do u have a pic of the knob that u turn to get the air fuel ratio to mix on the carb?
Bretto
« Reply #14 on: May 02, 2008, 10:20:04 PM »
The fuel air mixtures are controlled by the holes in the air filter, jet size's, needle height and exhaust type. So not as simple as just turning a screw/knob. Most mixture adjustment screws are only used to set up idle mixtures. Read the link it has a lot of good info about what controls the mixtures in the carbys at different times - cruise - power etc
spriceii
« Reply #15 on: May 03, 2008, 01:48:11 PM »
the link is not working.
Bretto
« Reply #16 on: May 03, 2008, 10:20:15 PM »
Quote from: "spriceii"
Just tried it then and all working for me, its 1.43MB with 27 pages
spriceii
« Reply #17 on: May 04, 2008, 10:54:24 PM »
i got it to go thanks.  im reading the air/fuel mixture area and which knob to i turn?  is it the one that can be reach with and allen wrench?
Bretto
« Reply #18 on: May 05, 2008, 11:23:49 AM »
Check out chapter 4 of the Hyosung manual on this site page 9, zoom in and you will see the "pilot screw" - may be covered by a blanking plug
larrycook
    • http://www.lccycle.com
EXCELLENT INSTRUCTIONS!
« Reply #19 on: May 21, 2008, 05:14:08 PM »
Bretto! Your instructions are more thorough than my instructions! Want a job as technical writer?
You do a really god job of explaning!
Thank's,Larry
Pages: 1 [2] 3 4 5
